sploo
Somewhat extinguished member
I've just acquired (another) Colchester Chipmaster lathe, and it was fitted with this motor:
The Chipmaster originally came with a mechanical CVT gearbox (so the motor runs at a constant speed, and the spindle speed is mechanically varied). In almost all used examples, the CVT is usually long gone; in favour of just a motor with a VFD.
This machine has no CVT, and was clearly being run from a 3 phase source. I'm assuming it must have been a variable frequency input (otherwise the lathe would be of limited use; fixed to only one speed).
My other Chipmaster has an Alpak II induction motor, and the datasheet shows that although it's a 50Hz motor, they can be run over a wide frequency range (anything from around 2.5 to 100Hz). I'm running it with a VFD, between around 10 and 70Hz to cover the lathe's speed range.
Is there any way I can determine if this motor can also be run across such a frequency range?
Also, it can be wired either star or delta (I need it in delta for 230v input). Usually the wiring diagram is on the inside of the lid, but unfortunately the lid is missing. Is it obvious to anyone (or is there a way of checking with a multimeter) whether the motor's currently in star or delta, and if it's in star, how to reconfigure it to delta? The bottom three connectors (yellow/blue/red) are UVW, with the connector on the bottom left being earth.
![20250125_134734.jpg 20250125_134734.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/177/177658-20250125-134734.jpg)
![20250125_134743.jpg 20250125_134743.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/177/177660-20250125-134743.jpg)
![20250125_134750.jpg 20250125_134750.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/177/177661-20250125-134750.jpg)
