MarkDennehy
I know, 8'x6' is barely qualifying as a shed, but we all have to start somewhere. In my case, that's an 8'x6' cheapo wooden shed, currently storing the lawn mower, some tyres (don't ask) and a healthy growing population of spiders and dust. I'm building a bench to fit on one side of it (and I'll knock up a second small shed-like cupboard thing later this year to store the garden stuff and patio furniture in for the winter, which is what the shed has been used for up to now). I'd like to line the inside with OSB, fit some LED lighting and paint it a whiter colour than "inside of an Indiana Jones cave set".
So, I have two specific questions:
1) Is there any point in putting insulation into the walls before lining them? I mean, it's an 8x6 shed, I would have thought the air gap alone would do the trick in winter if I had an oil-filled radiator in there for the really cold days?
2) Is 11mm OSB going to have enough strength to hang things off away from the studs? Or should everything go on a french cleat screwed to the studwork? Or is there a better material to line the shed with?
And in general, you guys have done this before and I haven't, so if anyone has any good ideas or things to watch out for, I'd appreciate the help!
Thanks in advance...
