1/4 inch router bit for mortises
Croolis
31 Jul 2024
Midlands
Hi, I have a quick question that I'm having trouble finding an answer for with a google. Want to cut a mortise with the green Bosch plunge router I just bought, which is a 1/4 inch router.
I have never used a hand router ( :eek: ).
First one I want to cut is in a 2x4 (or 47x95mm). I read that one should follow the 1/3 rule, and I want to do loose tenon, so I'm thinking I'll do 18mm slot so I can just cut a board for the loose tenon.
I understand how spiral flutes and up/down cutting works, but, as I have a 1/4 inch router, am I better off getting a straight edge non-spiral type that is wider at my desired 18mm, or should I use a smaller 1/4 inch fluted diameter bit and make multiple passes across the width. As a beginner, like. I mean, I mostly see upcut 2 flute spiral being suggested, but on 1/2 inch routers.
Cheers for replies.
I think it's a bit under powered for this task. It will tend to chew its own chips. I you wanna try then take it very slow and not to deep.
You could probably do it quicker with a chisel than a 1/4" router.
Got a bad shoulder. Looking at doing it with router and using power tools in general as much as possible. Are we saying a 1/4 inch router is inappropriate for mortise joints?
Another way is first drill out most of the waste then use the router to clean it out. A 1/4'' router is ok for a smallish mortise but the bigger they get the more it will struggle. I use the drill a lot for doing mortises and clean out with a chisel. The chisel work cleaning out is not hard like chopping a mortise from scratch. Mostly paring and the odd bit of tapping with the mallet. Not big swinging like on the prison rock gang.
John
In your circumstances I would use a small diameter router bit (6mm) and plunge cut in small steps. That would not overload a small router. Bigger bits would overload.
I have a 6mm collet come with the router. And an 8mm collet too. So a spiral two flute upcut?
I see vids for making jigs. I'll get some practice on wider flat boards as well before I start doing this stuff. I might actually have a 6mm upcut bit already for my little CNC machine (which I have barely used and am still ignorant about).
Cheers for replies.
