LancsRick
Morning all!
I've got a space in the bedroom that I'm going to put a built-in wardrobe in, and due to the fact that there are a couple of obstacles, I'm going to have to design and build it myself.
The main query I've got at the moment is what material and fixings to use for the shelves.
I'm going to put a timber framework on the 3 walls so a solid structure exists, and then sheet over them with a TBD material. For the internal shelves, I was thinking of just putting in some vertical sheets, with shelves mounted between the verticals using dowels at 15cm spacing. The verticals would go right through to the wall and have a piece of 2x2 either side of them to form a decent fixing, with the top and bottom sheeting for the wardrobe just being the "intervals" in between the verticals.
Whilst working out of solid wood would be ideal, it's cost prohibitive for me really. I'm therefore thinking of MDF with some good old elbow grease on the PVA and preparation side of things, with maybe 18mm for the verticals and 18mm again for the shelves.
Any tips or experiences? Maybe my Google skills are lacking but I've not turned up much!
Cheers.
Rick
Cheers.
Rick
