Don't agree. The basic apparatus for checking for straightness and flatness is your eyeball. You do it by
looking ; squinting along a length from the end or casting an eye over a surface from the edge. It's quicker and easier than fiddling about with straight edges - with the exception winding sticks, which are very handy.
Even if you have a straightedge, flat surface etc - you still are checking for straightness by
looking - unless you are going to go all round with feeler gauges or something
Winding stick tip; make them square section, then you have four faces to set against each other to check for straightness of the sticks themselves i.e. each face can be matched against any of the other four.[/quote]
Hello again
First I swipe the high spots off until I cant see light under the wood anymore, using my stinkin worklight
This should be an angle poise ..SOMEDAY I will find a suitable spring(s) and make 10 angle poise lights
using old aluminum box from redundant cable TV aerials and white faced aluminum panels from Aluminum Fascia and Soffit sourced from the new flats around the town after a storm
as it needs to be lightweight .
I don't mess with feelers I just wiggle the wood on the bench and I can see or feel where the high spot is .
I am soo spoilt with this wonderful top although I have a fire door aswell ....both are slippy too so I can clean the remaining dust off it easily and have a
gawk at the other end of the timber and not get dust on my head and down my neck aswell.
I seem to be a bit sensitive to the timbers I work with .
I have seen every planing video on youtube exc mostly in English , and have tried these methodical methods which should, in theory yield a perfectly flat surface but not so .... to my liking anyway .
I will soon be making a proper bench though, to the tolerance of this plate with the best, time tested stable wood I have in my possession .
Here's some pics of some stuff I like having ..although I will mention I already have scrapers
and I've added a single cut farmers own fine file (second cut??) for the scraper .
And another shot of stage one,de-nailing and cleaning removing glass and crud ....
although their needs be vicegrips there too .
You could do with a protractor too ...but check the bloody thing before you buy it if you want a good'un .
Even a plastic one will add consistency for marking out angles on a block, so you can check your grind and secondary bevels on your irons .
Make your own stuff when you can, like multiple scribes from steel nails
A bench grinder would be nice for these things ,but an angle grinder would get you by .
Keep your safety glasses in a box
Have fun
