Your Favourite Tape Measure(s)
I like the hultafors talmeter 3m for fine work, being able to accurately measure internal measurements is a game changer for cabinet work and metric only keeps it tidy. Just be careful to read the correct number when using the internal measurement flip out tail, I'm not going to lie I've cut pieces 10cm short a few times now and that's something Peter Millard doesn't talk about when he recommends it in his videos 😂
For rough work and outside I have a Stanley fatmax which has taken some serious abuse over the years but still going strong.
My preference is 8m Fatmax - when I was working, they took some very serious abuse and gave good value.
Now, I'm probably being a total numpty but, when I was surveying for a living, my brain struggled (just occasionally) to process a metric measurement using the lower scale style in the picture : 358 mm is (30*10)+(5*10) + 8. To me, it's much more intuitive to work with the Fatmax style scale on the top where 358mm is (35*10)+8 .
A Komelon (Korean) fan here. I have several in different lengths and widths. Good hooks including magnetic ends, good visibility, some types printed both sides, some metric, some combined imperial & metric, white, hi vis yellow or green. I kept on needing a tape when I didn't expect to so bought a few over the years.
One of the Axminster own brand tapes is a badged up Komelon.
Also good are the 2 and 3 meter tapes by BMI that curve the wrong way. This puts the edges against the surface for more accurate measuring instead of the middle of the tape touching and the edges raised up. This lives in the house for all those little measuring jobs.
Negative points to the Lufkin - the black one with dayglow green lettering (which is the only reason I bought one).
Expensive bling. These are not well made. They look great in the adverts but beware the American marketing hype. The blades are deeply curved for standout but are actually very thin and easy to crease. Anything that looks metal on the case isn't it's just flashy chrome finish on plastic.
My vote goes to the Bahco MTS-5-25-E
5mtr long. The blade lock is opposite to many, so the blade stays out unless you push the big orange button.
Strong magnetic hook end and generally I just find them a perfect size for me to hold and use.
Black on silver markings are also easy to read and If you have never used a tape that automatically stays when extended then I really suggest its worth a try.
I really liked this one when I got it. but it's not as durable as a stanley. but the imperial and metric scales are dead easy to read. and the hook is big and double sided with earth magnets on it. £2.95 from toolstation bargain bin!
    1.6 MB
    1.2 MB
    1.1 MB
Regarding your last point I have tried the Stanley autolock tapes and at first I thought they were brilliant and I was an instant convert.
But then they started wearing out really quickly and I realised that the autolock mech. drags the brake along the tape and this inevitably wears all the numbers off in just a few weeks.
Call me old fashioned but I like the numbers to stay on the tape 😀
Martin
tajima hi lock 5m for me, have tried most and definitely my favourite as yet, not the most robust but honestly have lasted just as long as any others i've had (if i get 2 months from a tape its doing well :ROFLMAO: )
The Tajima is one of the most accurate tape measures on the market, its Class 1 status means its tolerance is within 0.6mm over the 5m blade length. A very solid feel and the unique tempered steel end hook is twice as hard as traditional end hooks and ensures the user consistent inside and outside measurements.
https://woodworkersworkshop.co.uk/tajima-hi-lock-class-1-tape-measure/
Another vote for the Hultafors Talameter
Being able to use it as demonstrated in the top right picture is a game changer, for example, when cutting noggins, as it can effectively be used as a story stick
Also, easily accurate to 0.5mm, because it has a fine thin gauge that sits just over the top of the tape, where you need to read off the measurement. A bit hard to explain but the equivalent of crosshairs.
I'm partial to Starrett tape measures, as they pride themselves on accuracy. When I had shops I used to buy them 6 at a time-on sale, because as a tape measure can only sustain so many drops (bent hook) and wear (loose rivets on end). I wasn't shy about tossing them when I even thought they were toast!
I'm unfamiliar with this class 1/class2 stuff...never heard of it before, but If I had to rate ANY tape measure I'd put them in the base category, preferring to believe in digital calipers, digital measurement, and story sticks.
I would have to agree with you here. I too find that the upper style of tape leads to a lot less 'misreadings', than the lower one. This I have remarked on in a previous thread The wrong sort of metric tape
That was my excuse anyway, though I can have my 'numpty' moments with any tape
haha this is a classic UK Workshop thread. Sounds like there is little in it regarding tape measures. Let's have an argument about sharpening.
I like the Advent vice versa tape measure.
Printed on both sides, metric only and pretty decent quality 5m or 8m available.
Toolstation do them or Axminster with their own sticker on it.
Ollie
Ditto here with the added reason of being left handed friendly!
Honourable mentions for the Hultafors (rebadged Fisco) BT5M and Tajima G3
I got my last Deal from Screwfix in a Twin pack, So far they've been perfect for my needs.
SOURCE
Similar set here - just foreign stanley tapes.
To be honest, the ones that harbor freight sold for five bucks but gave away free with any other purchase for quite some time are decent, too (I checked the accuracy, of course).
Death to tapes in my shop comes via damage and not so much initial quality issues.
