johna.clements
but can give you a nasty cutTape Measures don't need Sharpening
Don't start with pencils! Took two on a job this morning, lost both of them, twice, during the day. Managed to retrieve them and got them in my toolbox. No idea if they will be there in the morning though.It's over there - next to your pencil .... ;-)
You need a stainless tape measure to stop the rust.Here is an angle nobody has mentioned yet - water ingress.
In terms of durability most tapes seem to last pretty much forever..... unless they get wet. And then they are toast, the tape itself just rusts instantly, takes just one or two hours to ruin it once the water is in there.
So if I'm working in the rain, I have to keep wiping the tape as it retracts so it's relatively dry inside.
I was thinking that a nice little gadget could be a rubber blade that pops down when you press a button and that could easily wipe off the water from the surface of the tape.
I suspect this is a fairly niche issue, just for those people that measure in the rain
Martin
I find it a real problem this time of year, I use my fingers a a brake on my tape anyway and they double up as water wipers when the tapes on it way back in, when i can remember anyway!Here is an angle nobody has mentioned yet - water ingress.
Martin
As a civil engineer I only heard of class 1 and 2 a few months ago. The work I was doing never had those sort of tolerances so I had no reason to find out unless I was inquiring.Ive got about 8 of the stanleys from screwfix, mix of 5 and 8m. As soon as one is wearing, i replace it and pass it on to my brother ( farmer )
But my favourite measure is a leica disto 2. I often work on my own and measuring joists and rafters can be tricky and time consuming solo. I bought the disto earlier this year, and ( not being convinced in new tech ) i did a lot of measuring and checking with it before i could trust it ..... its perfect, both in cabinets and along a 14m bungalow, it stores the measurements as you go, can be hooked up to your phone via Bluetooth etc.
Now, i will admit to having never heard of class 1 and 2 tapes, which is a bit poor! Ive been a chippy for about 26 years
Simple solution - make felt tip marks on any old tape? And you can read off the dimension at the same time!I have a wish! Several years ago ….some one (Lee Valley Tools?) made for a very short time a tape that was completely without markings. You could just mark onto it, a ‘story tape’. I saw it long after they were no longer marketed. I wish someone did them!
edited to add….
Well ! It seems they do still sell them, but I expect the import cost would be silly!
https://www.leevalley.com/en-gb/sho...apes/65359-lee-valley-story-tape?item=99W7850
I once cleared a bench off and found forty one pencils.Don't start with pencils! Took two on a job this morning, lost both of them, twice, during the day. Managed to retrieve them and got them in my toolbox. No idea if they will be there in the morning though.
Was that you being indecisive down at Screwfix ?I once cleared a bench off and found forty one pencils.
Yep I took the plunge earlier this year and treated myself to a Leica Disto, accurate and does area to so useful to work out flooring etc. just have to keep it steady when taking measurements or use the online app. Far superior to tape measures and easily done without some to hold the other end ( of the tape )After all the time I have spent banging on about my fantastic class 1 tape today I noticed printed on the blade "CE Applies to Metric scale only" and I spend a good amount of time working in imperial
Similar to @baldkev I got a laser measure a while ago, mines a Bosch, would not be without it now, spot on accurate to half a mill. Only downside I find is it can make you a bit paranoid about getting measurements EXACTLY the same.
Leica Disto 2 can measure pretty much anything, I don’t just use it for woodworking as it’s mainly used for measuring up for say skirting’s, new laminate floors , working out area of a floor or walls for tiling . It performs a variety of tasks including length, area and height measurements via Pythagoras therom. Using a target plate it can be used outside for setting out for fence posts and using the point to point setting the holes for fence posts can be accurately marked. In short it’s an accurate measurement device with multiple settings and functions-A while ago I compared readings from several tape measures I had. None agreed but the important thing to me is to use the same one on a job. I too like the Tajima but dont understand how the Leica Disto ( which one?) can be used to set out wood work.
Never, Never loan a tape measure. It will invariably come back with the end of the blade twisted
