wcndave
One thing that I don't quite get is the telescopic sliding table fence.
It extends about 30cm, this certainly could have been more, my Scheppach extended by 60cm odd...
However the main thing is the tape system. You can adjust the tape wherever, it's clearly designed to be moved about as it's not stuck down, rather has a locking wheel.
And there are two rows of numbers. If you put the tape so the far right of the stop is on the actual number (ie the tape is exactly relative to the blade), then I would expect that when you move the stop to the extension, and then move out the extension, the pointer on the lower half of the tape would show you the extended measurement. It looks like it ought to do this, but I can't see that it does.
The tape does not go on to the extension bar, so you don't know where you are at (the lack of pointer or some way to set stop accurately is a bit of a pain).
However if you did measure accurately, the stop will be at about 77cm, and the pointer on the secondary scale is at 87cm.
The secondary pointer is not movable, in fact that part of the scale starts at 80cm. I could move the stop out to 80 on the extension (with manual measuring or some jig), and then move the tape so the pointer is on 80cm, and then move out the extending arm. However it seems like an awful lot of faffing, and i have to spend ages setting the tape back again for normal cuts...
Any thoughts on this most welcome!
A final note on the sliding table.
I love having a ST, doing kitchen cabinet sides, I cannot imagine doing them on a sled of some sort.
However the mitre is secured in four different places, so it's rock solid, but it also is about 7cm from blade.
So if you want to rip a long board with more than 7cm on left side, you need to remove the ST mitre.
That means setting it to square again, and using the five cut method and adjusting takes time, and uses up a lot of boards!
I find myself now cutting with bandsaw or track saw, down to a few mm, and doing final rip on TS.
It's just a shame there's no way to remove mitre without losing settings.
It's not a deal breaker, and I still rather have the ST than not, but you need to occasionally plan around it.
The reason I say long board, is that you can pull the table back 48" which means any ripping of boards under 48" can be done without obstruction.
