archersam
On a roll with posts tonight so thought you might like to look at my new space. I had been working out of a single garage in my back yard which meant I could really only work in good weather as I had to take much of my equipment out of the garage before I could even get into it let alone work! As you will see I am now very spoilt but have since found out that I need MORE room :shock:
Boxing day at 7am - basic benches made from salvaged timber from a skip are in order
Stuck in a mezanine to use the extra height space and allow me to store stuff in the "rafters"
Installed a "finishing area" which I realised I needed after the extensive sanding of the sapele table that is posted in another thread meant that I would not actually work on another job as despite extraction and an air cleaner there was dust everywhere. A very valuable lesson indeed.
At least I know where everything is.....when a friend helps he has no idea!!
Recessed the SCMS so can use the bench for support for long pieces
View with the garage door open
Made a bench for my table saw:
Make up something useful to work on and to store equpment, BUT it also doubles up as an outfeed table for the table saw.
Posing with my new Christmas pressie (the Trend face mask!!)
Added the base to the radial arm pillar drill today as it was a pain to use where I had squeezed it in.
Couple of arcade machines for when I get bored (as if that is EVER going to happen!!!)
It is still being developed as I learn what works and what does not. Feel free to ask anything you like about the install, more than happy to give away information as I have sure been taking some from here. Thanks Sam
