Theres still variables before selecting the size of cable you need and the fuse size . Your proposed new circuits will rely on the size of supply cable to the workshop), if theres already a supply there then whats its size, type, length of run & existing protective device. If the supply cable is not already installed then where will it be fed from ?. Other variables include does the workshop have metalwork touching the ground (structual or water/gas pipes), will the proposed conduit be hidden behind walls within insulation - these can all have a impact on cable size and other regulations. If you were more local I would be happy to help where I could. Probably best to call a a local electrician in the local paper for an appraisal before you throw any money at it !
