billw
The Tattooed One
Right - so I have figured that one reason I struggle, especially now the nights are drawing in, are that my working space is lit by one 40W lightbulb. Not great to say the least. Plus the only workspace I possess is my bench, and part of that is gone because I've bolted the bandsaw to it. So really, I have 2/3 of a small bench and no other flat surfaces. A lot of my tools are in a roasting tin sitting on a large cardboard box of junk, the rest of them are strewn all over the place, or hanging on the occasional nail in the wall.
So, I've decided this has to change before I can get round to doing any proper work. So, here's my initial design and some notes on which I'd love some feedback. Sorry that my skills aren't good enough to put in the extraction pipework, although it'll all run up to the ceiling and then off to the chip extractor which will be outside of the area shown.
So:-
1. the bench isn't my current one, it's the one I'm planning to build, current one is smaller.
2. Machines have all been positioned to allow for maximum in/out feed.
3. The five base units will all be made from solid timber (probably 18mm cherry) and will mostly be drawer units (1x cupboard under the thicknesser)
4. The worksurfaces I've yet to decide upon although I've set them to 34mm. Haven't decided what material to use yet. I remember seeing an MFT bench design on here that used some black-surface material that looked really good but I can't find the thread.
5. The planer weighs 9k, so I think resting it on two units should be stable enough.
6. The bandsaw is 30kg, so not sure on my plans about resting it on two units.
7. The thicknesser is 35kg, and I put it on a more strengthened base, not sure why I figured 5kg was the breaking point! (Actually I never looked up the weights until I started writing this post).
8. The white shelf is actually a holder for a series of 300x300 LED panels that I'll use for the main lighting. The shelf is 3m long (it's just approx) and I'll probably put 4 or 5 panels in it.
9. I might stretch some boards out of that shelf over the workshop and put some more panels in - simpler than trying to fix new lights into the ceiling and can be easily removed when moving house at some point).
10. The boards on the wall are 18mm ply, to which I'll attach most of my tools.
And that's it!
So:-
And that's it!
