One of the guys that passed (with 100% no less) I wouldn't let switch off a circuit breaker**.
jlawrence":el2l388w said:It might be cheaper to pay building control if it's only a one off thing, but if you're re-wiring the whole house you're likely to be doing it in stages - and thus needing multiple sign offs. ....l.
RogerS":32c4lim7 said:As far as i can see even though you might pass the course, you still have to register with one of the Competent Persons Schemes
would not":30hefo1s said:.....
If you choose to get the council in then they will tend to really go to town as most councils use registered electricians to test and sign off, so it could work out more.
wobblycogs":25ycezm4 said:Ok found what I was looking for http://www.theiet.org/publishing/wiring-regulations/part-p/. Check out questions 8 and 10. I interpret that as meaning that long as you hold an EAS qualification (I do) you can sign-off your work simply by notifying building control before starting. My local council seem to agree with this interpretation as I checked with them before starting. This route to conformance seems to be rarely used as the guy at building control had to go and look it up.
One thing I remember I can't provide documentaiton for is a period inspection and test which is a bit bizarre considering it seems to be ok for me to run in a complete new circuit.
wobblycogs":3pty51r5 said:I agree it's a complete dogs dinner and I would argue unnesessary. The whole thing was set up save people from bad wiring but even the govenment admit that only 10 people a year were killed (I can't find a figure for post Part P). When you compare that with the 3201 deaths on the road in 2005 it seems strange anyone would even care. Anyway, that debate has been done to death and we have to live with the consequences of Part P now.
I think you are probably right about needing to be a member of a scheme to work on any site other than your own home. There is no way you would get liability insurance if you were a member.
RogerS":1qrfl6id said:would not":1qrfl6id said:.....
Not round our way. They take a quick look and if seems OK and you seem to know what you're doing then you get your completion certificate signed off.
