Workshop Build - 5m x 3m
UPDATE #5
Nearly there! The roof set me back quite a bit, swapping the 4x2 to 6x2's. During this time we also decided we might as well put a skylight in there so, seeing as this is a 3m span I thought it would be a good experience to build a few flitch beams to support the skylight either side. Its a triple glazed, aluminium 600x900 skylight so it quite heavy, approx 50kg. Had to invest in a mag drill to put the holes in the 10mm steel bar, annular cutters are my new best friend! Couldnt believe how much easier it was compared to a standard drill bit and hand drill.
I used climbing straps around the adjacent joists to make sure it didnt fall on top of me while getting the flitch beams into position
L brackets used to secure roof joists down, you can see the remains of the old joist hangers here.
I got a great deal on some second-hand window and doors from Greendoors.co.uk. £700 for the 2, including delivery. The door is HUGE but I wanted it like that to make getting tools in and out easier. I started by framing the front wall. I got some second hand tyvek flexwrap to flash the top and bottoms.
I used permaroof for my EPDM kit, on their ebay store they sell firestone EPDM offcuts for quite a bit cheaper, I snagged a 7x5m sheet saving about £100. Installing the rubber roof was very easy but I did find the glue set very quickly as it was a warm day and I'm doing this by myself.
That's an amazing tip thanks! I need a new window for my garage and I'm building a garden room once the garage is renovated. Looks like I could save a load. I was thinking of trawling FB marketplace, which isn't a bad idea, but being able to pick from a catalogue would make things a lot easier.
Your build looks amazing btw - great job!
I've seen a door on Greendoors web site that I'm interested in for an upcoming workshop build I have planned, recently realised they are located around 25 minutes away from me so I'm thinking of going to take a look
