markblue777
Hi All,
I am looking at doing a side extension and there are a few access points that will be under the extension. I am trying to work out if they need to be moved and if they can remain and something else then created to tap into it.
I got a couple of pictures of what I'm looking at
The bit i am interested in is the one with the top off. Looking in it, it was full of cobwebs and after removing them i saw it was a sealed unit and there was not holes in it
There is one at the back right of the picture (near the gutter down pipe) that is that same however this has some water in it, again it is a sealed unit so I think the water is just rain water as the seal for the slab lid to the plastic is not that tight.
In front of that is the rod access point.
From what I can tell I will need to shift the rod point so it can be accessed outside but the other two bits I am not sure on, I'm not sure if they are some sort of way to splice into the line.
A few more pics are below, I looked online but cannot see a similar type of fitting.
Mark
Mark
