At first I was going to argue against using centimetres, but then again, it's just what I do when I come to think that.
It depends. At work (metalworking industry) I use mm only. When I design something for the house or a piece of furniture, I still use mm, but end up building it in centimetres. When actually building something without plans I generally use cm, but if the last millimetres are important (on house-scale jobs they seldom are) I mark it up in mm. On the other hand I really had to think it hard, as I do the conversion without even giving it a thought.
But, as Finland has been metric since 1887, there shouldn't be any reason for me to use imperial measurements. Still, a two-by-four is a two-by-four, a 18x100mm board is a "three quarter board" etc. Old habits die slow and as I've been taught by the old school guys who used these.
So if you think that you all should be converted to using SI system in 30 years, you'll be hanging to those old measurements still at 2107
The lapps (living in Lappland) regularly use a distance called "poronkusema". It means the distance you can travel with a sled driven by a single reindeer before it has to stop for a pee. A reindeer can't do it running, so if you don't have a pee break every 5-7 km, it will get some sort of a seizure. And this story is true
Pekka
P.S, Scrit mentioned about the "duim" (pronounced dow-m) in Netherlands. Over here inch is called "tuuma" which would be pronounced too-ma, with the same linguistic background in them. In the scandinavian languages inch is a tom, tomme or tomma, which is of the same origin as tumme, (=thumb), so it's probably some kind of a viking invention again, the whole inch business :wink:
