wolverine sharpening roughing gauge
ThornOfCamorr
29 Oct 2024
London
Hello,
I'm very much at the beginning of my woodturning journey, so this might be a very stupid question...
I've sharpened my roughing gauge (got it 2nd hand) on the grinder using the oneway wolverine jig. I got a sharp edge, but I failed to grind it "square across". The tips left and right are of the same height and that runs perpendicular to the flute, but "middle" of the edge is shorter than the tips (kinda a bit like an inverse fingernail profile). Apologies for describing this clumsily, please refer to the pictures. I also noticed that the flute is not square to the handle.
I used the tool on the lathe and it cut brilliantly, although i had the feeling once tilting the flute to the side that the tips engaged more heavily, making it more prone to catches (I had a few, but all very controlled and not dangerous - this ofc can also be due to me still figuring out what I'm doing). I do wonder if the geometry of my tool's blade is the problem here.
I've looked at a few youtube videos on how to use the wolverine jig, but can't notice anything I'm doing different. On question here is: when grinding and turning the tool, do you aim to always grind in the center of the wheel or does that turning motion also mean you turn more on the left/right of the wheel?
I hope my question makes sense and I'm looking forward to your enlightening advice.
Looks like you are using the long arm of the jig, as you should, but the bent shaft is causing the change in angle.
You could use the adjustable platform close in to the wheel and rest the back of the flute on it. That way the handle angle is irrelevant. With the grinder off adjust the platform until the gouge is angled correctly to the wheel then you are good to start grinding.
You'll be taking a fair bit of metal off so take care not to let it overheat
Hello,
View attachment 196027View attachment 196028View attachment 196029
I find that using the Wolverine jig does produce a slight arc to the grind, but I think the amount you are getting is being increased by the bend in the tool shaft. If you use the platform, as Tris has suggested, you will mitigate the impact of the bend. Also, if you've been watching YouTube videos, you will have seen people marking the grind face with a felt tip and adjusting the angle of the platform until you get nose-to-tail coverage when the wheel is turned by hand. Provided you then keep the back of the gouge flat to the platform whilst you rotate it , you should get a good grind.
Thank you both - I've another roughing gauge I sharpened as well. It does not have a bend in the tool shaft. There i only have a very slight arc. So it really might be that. Tried earlier and could easily bend the shaft back... not sure what i should make of that yet :D
I've done the sharpy-method, but the bevel was so off, there was no sharpy required to see effect of the wheel :D
Grinding jigs keep the tool at the right angle and allow it to move through the right path but they don't control how much metal you remove at each point around the edge. That's down to you and by the sound of it, you need to work on that part.
I have recently had to go through and sharpen all of the donated gouges, skews and the flat work joinery chisles at the Men's Shed I belong to and the best way I found to get a straight edge on the roughing gouge was to do a careful grind with the goiuge at 90º to the wheel using the adjustable platform and grind the 'sharp edge' until it's flat all the way across. That gives you a reference to work to.
Then, as Tris said, you will be taking a fair amount of metal off, so be careful and make sure you dunk the end in a water contained to stop it overheating. You can see when it's all sharpened by looking for light shining off of the flat you have just ground on to it. When there's no reflection you should have a sharp edge.
On the Sorby Pro edge there is a block with a V cut in it , The back of the gouge sits in the V and when presented to the grindstone results in an even cut / grind across the gouge
Quench carbon steel before it blues, but don't quench HSS tools. Why use a jig for a roughing gouge? It's a straight across grind.
Why don't you quench HSS?
On the One Way system it's as easy to use either of the attachments. All you have to do is get the correct angle on either.
Well, we live and we learn, so thank you Phil. I had (now won't) been doing the quench routine. For about 25 or more years now I have, but I don't let the tools get toooo hot anyway.
I will be showing my Men's Shed members some sharpening ways in the near future and the way I can imagine the stuff will get sharpened will put water out of it! Until some members walked into the Shed they didn't know which end of a screwdriver to hold :rolleyes:
