Thanks Triggaaar the encouragement makes it worth while. Will look forward to your W.I.P. when you have a go.
I made a start on making a spraying booth from ripping’s and polythene sheet in a space between the back of the workshop and the fence. This is one of those places that is hidden from view and becomes a dumping ground for items that should really go off to the tip. Even when cleared I couldn’t get a start as there are five Holly trees with branches overhanging into my garden that had to be trimmed back and then taken to recycling.
Finally got started, all suited and booted.
As stated, never done spraying before, it took one hour to set up, five minutes to spray and one hour to clean and pack up. Not satisfied with the results either.
First suspending the door from a hook was a bad idea, kept spinning round, could not get an even coat despite watching all the videos on u tube. Needed somewhere to put the spray gun because you cant put it down if you have to make adjustments for what ever reason where do you put the gun?
So for my second attempt I got a little bit more organized. First task was to make some form of holder for the gun and this is the first thing that came to mind.
And this is it in use. Worked O.K. will look closer to make improvements but for now will suffice. Also got plenty of cleaning gear to hand. A quick scan of U Tube (must remember to put the hose over my shoulder).
Results much better (not perfect) but better.
Closer inspection shows what looks like a run but its not. It was silly me seeing a spot of dust tried to flick away with my finger which resulted in bursting the forming skin. Lesson learnt “don’t touch!” First lesson was when starting to spray there’s a temptation to target the object. No! fire above it and then come on to the target.
Close inspection.
Inspection next day it was still there but not as noticeable a bit of sanding is in order. This is the undercoat.
Have brought the other doors back to Sussex cant wait for attempt three.
