marcros":10rw6635 said:there is a good thread on the forum about fitting one of these vices- well worth a search. I cant remember the author unfortunately.
morfa":39ildn1z said:marcros":39ildn1z said:there is a good thread on the forum about fitting one of these vices- well worth a search. I cant remember the author unfortunately.
Yeah, found that. Hopefully clamping a piece of wood the right height in the clamp so that I can rest most of the weight on the floor should do it. It's a lot heavier than I had expected.
carlb40":1cc61tu4 said:A wider bench is useful if in the middle with access all the way round? If it's against a wall, you will struggle to reach the rear of the bench.![]()
rich.h":3s6algqv said:Having just done my first bench I can say I'm glad I cut down the width. The original plans called for a bench 26" deep yet I find even with just 21" I have more than enough space. The channel in the back for holding tools happily doubles up as extra support for wider pieces of work.
morfa":379rmzum said:rich.h":379rmzum said:Having just done my first bench I can say I'm glad I cut down the width. The original plans called for a bench 26" deep yet I find even with just 21" I have more than enough space. The channel in the back for holding tools happily doubles up as extra support for wider pieces of work.
Rich, what are the dimensions of your bench then?
Currently I've got:
14" for the solid front of the bench
8" for the well
2" at the back - that's the apron
Which is 26" in total. I really don't want to loose anything of the front and the well fits a plane on it's side nicely. So not sure I want to take anything off that either. I suppose I could make the well a lot deeper and a lot narrower as at the moment it's quite shallow.
morfa":1my71a25 said:DM - thanks for the photos. Looks really nice for a 'stopgap' bench.
I think I've settled on a 20" width. But I've got enough wood to go up to 22".
Got both aprons done. They went together fairly well. Also done the main benchtop. Which went less well. I'm basically gluing 2x4s together to make a 4" thick worktop. But one or two of them seem to have 'splayed' out slightly, so while it's ok at one side, the other side has a small gap. Also cut all the pieces for the legs now. I'll post some photos later on. Hoping to finish it all over the weekend.
MickCheese":3iomy2az said:14+8+2 is not 26 unless I have read that wrongly?![]()
Mick
marcros":gyyhbv8o said:you could always look at having a well at the back, the far side of the apron, if it is going against a wall. I am about to do that on mine, because i need to have the back edge of my bench 6 inches from the wall (for a router planing sled I am making)- i may as well use that gap. Or, you could fashion something that fits into dog holes at the front, so that you can move it to where you are working on the bench (or even just held down with a holdfast). It would be more of a tool box that a well, but would serve the purpose, and you could just move it as needed.
If you wanted to be super fancy, you could make some dogs and thread one end. then make a nut to fit them, and hold the box between apron and not.
