pe2dave
What wax to use for steel tools, cast iron beds etc please?
@Argus Wood will withstand a bit of damp, steel less so?
Perhaps. though I did ask about protecting steel?Indeed - but the wood needs some protection. Renaissance wax is also an excellent cleaner and polish which leaves a protective coating.
I've mentioned this elsewhere on this forum where the issue of rust-prevention in unheated workshops seems to be centred on controlling the Relative Humidity (RH) in the space, the real issue is keeping the metal temperature above whatever Dewpoint temperatures will be encountered throughout the cold months.
Only issue with WD40 and similar is that if you leave it for a long time it dries out and leaves a hard deposit on the surface. Still protects it but doesn't look great, and has to be removed with thinners or petrol soaked rag. so fine for day to day, not so good for stuff stored for several months. I can see that Vaseline would probably work. Most important thing is to cover it up, but with something that can breathe. I just use cotton bed sheets. If you get dust on the tool then this will absorb moisture and make matters worse.No one has mentioned spraying the lot in wd-40 or my poor man way of smothering the machine in pound land vasiline..
