I just had a quick look around the house. (I know, I know. I should be doing some work - it only took minutes!)
Drawers in 9 pieces of furniture with hand made DTs (not made by me):
the back pins on 7 were trapezoid and 1 was triangular ("single kerf")
The front pins on 6 were triangular ("single kerf"), 1 was in between - probably started as single kerf but got widened. 1 was trapezoid.
The odd one out had peculiar shapes all slightly different!
Large majority conform to what I think was the most common pattern; single kerf at the front and double kerf at the back. This was true of the best (nice little davenport with mahogany 2ary timber and ebony, ebony veneer, birds eye maple as 1ary timber) and the worst (wardrobes and 2 pine chests of drawers), so quality and materials seem to have nothing to do with it - it's just best (and easiest) practice.
A triangular back pin is least likely as drawer sides usually overshoot the back in which case a triangular pin couldn't fit - a trapezoid becomes inevitable.
The arts n crafts DTs are all trapezoid, for no good reason other than fashion. Strength doesn't come into it as in ordinary furniture DTs never fail, large or small. Even that wreck of a dresser (which I worked over in another thread) which arrived in bits, had DTs still in good condition, just needing sticking back together again. Incidentally (Rob take note!) what had failed in every drawer (7) was the bottom edge of each side, due to having slots, not slips.
