A
Anonymous
Guest
Well - each time I start up the extractor you can see this fine haze of dust coming off the bag - if you "beat" the bag then even more comes off - this is not dust which has settled onto the outside of the bag and then is being blow off - why should it be - the bag has an "outbound" draft when in normal use so no dust would settle on it
You are right - some of this extraneous dust does come directly from my work at the lathe (my main dust producer) - but the reason for this is that the extractor is not delivering the required CFM to the lathe because the bag has been blinded by the dust.
So my approach is
a) build a unit which retains ALL of the dust
b) build a unit which does not have filters which "blind" filters quickly
This will mean that the CFM stays high - and the dust which is captured stays where I want in (in the waste drum)
This unit is going to be sucking 800 CFM - my workshop is about 1200 CF which means all the air in the workshop has the opportunity of going through the filters evey minute and a half - obviously this will not explicity happen - but I hope by position the work and the cyclone apart I will create a degree of circulation of air which will be good too
So my approach is
