Corneel
Peter, just a question. Do you ever use the chipbreaker on difficult timbers to prevent tearout?
Jacob":3a3zz800 said:Do you offer the Stanley SW 4 Peter? It's a serious contender and a third of the price!
Corneel":ozt94j44 said:Peter, just a question. Do you ever use the chipbreaker on difficult timbers to prevent tearout?
bugbear":383f1plb said:dann":383f1plb said:Im after some thoughts on bevel up and low angle smoothers, yes i have both no 4 and 41/2 smoothers but i really fancy a veritas having got the low angle block plane and being so impressed with it......
Here's a fairly detailed and careful review (sadly un-dated) from Derek Cohen.
http://www.inthewoodshop.com/toolreview ... other.html
BugBear
Here is a recent article I completed titled "Centre of Effort in a HandPlane". Read it at your peril. Read it if you are suffering insomnia. Or a masochist wishing for a headache. Or curious.
http://www.inthewoodshop.com/Commentary ... Plane.html
Regards from Perth
Derek
Compare for example an LN #4 and a LN low angle smoother with a 33 degree honing angle. Do they feel different in use? They are both exactly the same length, handles have the same place and angle. They even weigh almost the same.
Jacob":2xa4nkhm said:Wherever (whatever) the "centre of effort" is, more weight means more effort. :shock:
Corneel":1rhougcq said:I've discussed this before with Derek, but I am still at a loss what centre of effort exactly does in a plane.
Surely the user directs the force, whatever the plane. More mass means a slightly smaller vertical but a greater horizontal vector overall. But as we know, in use we direct force as we choose - e.g. towards the front at the start of a cut, and at the back near the end.Jacob":8gghsyen said:Wherever (whatever) the "centre of effort" is, more weight means more effort. :shock:
Hi Jacob
That is essentially what I am saying. It is where the weight is directed that is important, and how the differing designs of a plane direct it there.
Regards from Perth
Derek
Why would it need more force?..... The BD may feel more powerful as a greater degree of force is needed to more it forward......
Jacob":2wkl0b0r said:Surely the user directs the force, whatever the plane.
Corneel":4clwowte said:At .5 to .75 mm he is too far from the edge in a smoothing plane. That's more a setting for a jack plane. Try 0.2 mm or as close as you can get. You will be surprised how effective the chipbreaker can be.
There aren't any planes like that are there?bugbear":2hwjkv5r said:Jacob":2hwjkv5r said:Surely the user directs the force, whatever the plane.
Yes, but the plane design is a factor.
If you consider hypothetical planes with very deep bodies (so the handle is very high)
Easy - one hand each end and you can direct forces how you likeand very long bodies ..... latter directing force vertically becomes difficult.
What principle? "Planes with handles in the wrong place"?With the principle understood,
I always understood the Razee to be school model for smaller people.it is then easy to apply it to less extreme (and more realistic) cases. One design option clearlt driven by such consideration is the wooden razee jack.
Peter Sefton":vll5dj76 said:Corneel":vll5dj76 said:At .5 to .75 mm he is too far from the edge in a smoothing plane. That's more a setting for a jack plane. Try 0.2 mm or as close as you can get. You will be surprised how effective the chipbreaker can be.
As I said it depends on how much camber you have on the blade, if I was getting students to try setting to within .2mm I would need an extra Tormek for all the damaged blades, but it sounds like a good idea if it works for you.
But in any case it doesn't matter a jot what it feels like - what matters is the quality of the planed surface, how quickly you can get what you want, how convenient the plane in terms of fiddling time etc etc.Corneel":nhn2p7hb said:.....
I still don't know what makes a BU feel different then a BD. I wonder now if you would also feel a difference if you would use the planes blindfolded. Derek, you are the psychologist here, how about a test with some innocent volunteers?
Jacob":8v9u243d said:There aren't any planes like that are there?bugbear":8v9u243d said:Jacob":8v9u243d said:Surely the user directs the force, whatever the plane.
