Zeddedhed
Having got through three (yes, three) sets of stiles in a recent door build I'm now half way through prepping set number four.
The previous three sets developed varying degrees of wonk, wind, bow, twist etc either after or close to the very end of the prep process to the extent where they were no longer useable at the desired thickness.
Set number 4 have successfully been brought down to thickness (44mm) and now require bring to width (90mm) which means ripping off about 55mm and then a couple of passes through the thicknesser.
I've attached a few images showing the boards as they are now. You'll see that the LH board whilst mostly straight grained has several knots along it's RH edge. knowing that knots potentially mean stress points in the timber, which would be the best way to go here - remove the bulk of my waste from the knotty side, leaving the timber free from the knots, or leave the knots in. I'm really not bothered about aesthetics here. I simply want to avoid adding to my stack of bowed and twisted door stiles.
