For installing (site) I use:
Adjustable mouth block plane
Low angle jack plane (which always gets a few comments)
1in shoulder rebate plane
*Bull nose rebate plane
Spokeshave
Even there the bull nose is really a luxury. For workshop I also use:
Carraige rebate plane
*Compass plane
The compass plane is a luxury, but has its' uses, such as working curved counter edgings, etc. , but it, too, is a luxury.
Between them the low angle jack and block plane will do most of what I need, because I rarely need a smoother for much. Unless you are routinely planing stuff more than 4 or 5 feet long a jointer is a luxury. The shoulder rebate is useful for cleaning up housings and tenon joints as well as blending in hardwood skirting joints, etc. The bull nose is a luxury as most of its' duties can be performed by either the shoulder rebate or a decent sharp chisel. The carraige rebate is ideal for cleaning-up multiple pass door frame rebates. I should add that I also use a power planer to do most of the hogging work simply because it's faster and much less effort.
This lot will go home with me at weekends for work on the house and for doing foreigners. They work well but a decent set will still cost around £500 to £600 new if you omit the compass plane and bull nose.
big soft moose":kn3rmyvs said:
I figure i dont need the rabbett, strikeblock, plough, moulding, and snipes bill on account of having a dewalt 612 router.
You DO need a rebate plane. How else can you fair-in tops of skirtings, clean-out housings (when you have to cut them into already fixed pieces) and tidy-up multi-pass rebates because your router leaves witness lines (like in a door frame)
