Random Orbital Bob
chipmunk":2gdeygxy said:Bob,
Skipping a few grits if the finish off the tool is good is obviously normal and to be expected but what I was reacting to was the suggestion that somehow a starting grit of 240/320 on a bowl was what was reasonable all of the time and anything else was a sign of incompetence.
I was just redressing the balance - Bert Marsh was probably a little extreme in the other direction but if you check his book he says that he always started with 80-grit because he claimed it cut quicker and generated less heat. I was lucky enough to see him in action and indeed I can confirm that is what he did.
Jon
Fair point Jon. Its interesting how many different approaches there are isn't it. Clearly Mr Marsh is a veritable guru and it almost seems rude to challenge that approach. Yet I just cant see the logic in starting with a grit which will actually take the work "backwards" in terms of it's scratch pattern (assuming of course that the tool has left a finish beyond 80 grit). I guess Bert had chosen a "point in time" with his turning when he drew the line between tools and sanding. It's predictable and repeatable and probably very consistent and that's probably what he liked about the method. Almost despite the wood...you know where you are every time.
I think my pathological hatred of sanding has driven me in a different direction
