Whats the best 18 volt drill and impact driver.
I'm not sure if the OP has given up in disgust with the rest of us or not, but as someone who uses drills a lot I can recommend having both the Makita DHP481 along with a Festool C-18. The Makita DTD 152 Impact driver which came with the drill is also very useful. I use all of these frequently and each one is suited to different tasks quite well. A more proficient impact driver would be an advantage.
Admittedly this is a fairly high investment but I know these tools will do the job, do it well and do it for a long time. I also know that I won't have to charge them every time I use them and they will hold charge for a very long time. I have also used an Erbauer drill which costs a fraction of the cost, which was fine for various tasks and was much easier to hold for long times due to lightness, but needed charging a lot more often. I also rate the parkside drills for their costs.
The Makita DHP481 is a real beast and can easily drill through concrete as well as run a 38mm auger through 6" of oak, and is as good as my corded SDS apart from locked chisel use, so I rate it highly and wouldn't be without it. The Festool is b****y useful for getting into spaces no other drill can reach and the impact just speeds things up and will drive harder than the other two.
If I didn't earn a living through making sawdust I really wouldn't need them, but regardless they make any job a hell of a lot easier.
If the OP hasn't made a choice yet and is near Petersfield I can let him/her have a play.
Regarding the Impact driver argument, For many jobs they're not necessary and sometimes counterproductive, but they do have their uses (hammer) (hammer) (hammer)
Regarding the Impact driver argument, For many jobs they're not necessary and sometimes counterproductive, but they do have their uses ... :lol:
Which was exactly what we said. =D>
When I first got an impact driver I thought it was amazing and used it for everything. Now I just find it noisy and it only comes out when needed (which is very rare for me but it does depend what you do).
