CarlC
...Between a Bevel Edge, paring and Mortice Chisels?
thanks Carl
thanks Carl
chisel":35ivsk54 said:Hi Carl,
There's many on the forum more qualified than me to explain, but as no one's come along yet I'll try my best !
Bevel-edge have the long sides relieved at an angle that allows them to clean up between the tails on dovetail joints where the sides angle inwards.
Conversely, mortice or firmer chisels have the long edges at right angles to the back/front of the chisel. This prevents them from bieng used on dovetail joints, but leaves more metal and therefore strength which is good when doing deeper mortices and allows them to be used with a levering action without fear of breakage when cleaning out the waste in a deep mortice.
Having said that about mortice chisels, some of them do have a very slight angle grind on the sides which some people prefer, but nowhere near as much as the bevel-edge types.
Paring chisels I am less sure about but think they generally have longer blades to make it easier to use with two hands when doing fine accurate paring on the end of a piece of wood, the longer blade also helping registration against the vertical cut surface.
Hope that's some help until the experts arrive !
Cheers, Paul.
