Hey, how did you get on with the saws?
Tenon Saw Problem
Tenon Saw Problem
I have to say, I don't agree with that assertion Mark. The afore mentioned chisels have been involved in joinery for almost the same length of time as myself, having served my apprentice in the late 1950s, which is around the time when the chisels were introduced. Early in my career, I bought some. At that time they had a shamrock, as a trademark, on the top of the blade. and their adverts used to read, 'Tempered from edge to trademark.' I still have, one of the originals and it's replacement and I don't think the replacement edge is thick at all for a chisel. However, now being classed as a 'grumpy old man,' I could be wrong.The two brands you mention are probably amongst the worst you can buy, they will hinder you with their massively thick edges and poor quality steel.
I can recommend the Ashley Isles bevel edge chisels, really fine edges and good quality steel and the Robert Sorby bevel edge chisels, again, fine edges and good steel.
As for sharpening get yourself a guide, the Eclipse type is probably the most versatile and cheapest, this will give you a consistently accurate edge whilst taking off the minimum of metal. Also a fine diamond stone will do to start with, no hollowing of the stone with these unlike oil stones. When your confidence and ability grows you may want to delve into waterstones or even micro films both of which are very good but stick with the guide, I've yet to meet a free hand sharpener who can repeatedly sharpen a chisel to exactly the same angle, this approach wastes steel and shortens the life of the tool, in my opinion.
Regards Mark
Shnapps95 your old chisels may have been better quality, I was referring to new ones which are as I described.I have to say, I don't agree with that assertion Mark. The afore mentioned chisels have been involved in joinery for almost the same length of time as myself, having served my apprentice in the late 1950s, which is around the time when the chisels were introduced. Early in my career, I bought some. At that time they had a shamrock, as a trademark, on the top of the blade. and their adverts used to read, 'Tempered from edge to trademark.' I still have, one of the originals and it's replacement and I don't think the replacement edge is thick at all for a chisel. However, now being classed as a 'grumpy old man,' I could be wrong.View attachment 180449View attachment 180450View attachment 180451View attachment 180452
Well, this is mostly guesswork. But I would reckon the steel composition is better and more consistent nowadays. In the US, they did a 'longditudinal' analysis of Disston [then the world's leading sawsmiths] saw steels. The manufacturing dates spread from 1865 [for the backsaw] to 1955 [for the D23].The results are shewn below.What is it about old steel that makes it better than even respected modern brands.
I accept that, in pursuit of lower costs, the quantity of expensive elements like chromium, nickel, tungsten etc used by quality manufacturers may be compromised - the result sometimes being close to ferrous butter.
I assume metallurgy has advanced somewhat over the last century to understand how the precise addition of other elements optimises material properties, controlling the production process (timing, temperature etc), and accurately testing the output (characteristics and chemistry).
So what magic did the "old timers" use - or is it just nostalgia for the old days when skilled artisans sweated over fiery furnaces and "men were men"??
Wet and dry paper on a thick glass plate is cheaper to set up and works very well, so is a good place to start. Personally, I like diamond 'stones' as they are flat, and a bit less messy. I usually then put a polish on with a fine water stone, but to be honest, I don't know how much practical difference it makes in most cases. So, both approaches work fine (as do other stones, of course).'Scrary Sharp' sharping vs Diamond Stones for sharping. Have you tried both methods? Which one do you prefer?
