devonwoody
Thanks for your advice and information, (I have had them stored in the shed some time now around 6 years at least I think.) The wife thinks a warm holiday would do the trick as well.
jimmy_s":f9sznl77 said:....... Air source heat pumps are........
MikeG.":3rvv3885 said:jimmy_s":3rvv3885 said:....... Air source heat pumps are........
......air conditioners with good PR. How we have been sucked in by the greenwash on these is beyond me.
HappyHacker":1857b6i7 said:current models do not produce water at 80 degrees so larger radiators needed,
DBT85":19bupck6 said:HappyHacker":19bupck6 said:current models do not produce water at 80 degrees so larger radiators needed,
Note to self, do not touch any radiators in HappyHackers house.
jimmy_s":2hpbatgi said:......The SCOP of the newer air source heat pumps are a lot better than they used to be.......
I believe that for condensing boilers you also need a return of around 55c or lower. Generally effeciency goes up the lower you run it all.HappyHacker":2aiklkok said:DBT85":2aiklkok said:HappyHacker":2aiklkok said:current models do not produce water at 80 degrees so larger radiators needed,
I am very old fashioned and have usually worked on 80 C in and 60C out. Modern thinking appears to be to use a lower temp in which requires larger rads to get the same output but is claimed to give a more even temp across a room and an increase in efficiency. I believe the recommendations for vulnerable people have also increased the use of lower temps as with bath mixers. Unfortunately I am not in a position to go around changing all my rads.
When my children were young they learnt not to touch the radiators and never got burnt.
