Hello,
I would like to ask if there is an acceptable gap between the straight edge and the wood when checking along the width of the board when hand planing the face or edge when hand joining the edges for glueing. I have seen many videos on the subject where instructors tell that no light should be visible, but I cannot achieve that across the full width of the board or full width of an edge. When instructors check for the light under their square or straight edge, there is not enough resolution to see if there is actually no light, or the gap is tiny and they consider it to be OK.
For faces of the board, I can get 0,05 mm - 0,1 hollows across the width of a board (e.g. 150 mm) and for edges, I can get similar results, but the line seems to be wavy for me. If the width of the edge is 30 mm, there are one or two places with miniature gaps (below 0,05 mm), but I steel can see light through them.
There is either a bump in the middle across the width, or one side is higher than the other. I have never encountered a situation where the middle of the edge would be hollow.
When I move the square along the length of the board to check the light, the contact point starts usually at one end of the board, then goes to the middle of the edge and then goes either way to one or another edge of the board.
I have almost never found a section, in which I have seen no light under the straight edge, although the gaps were below 0,1 and sometimes below 0,05 mm.
I check the gap with feeler gauges, that can measure up to 0,02 mm (that is 0,8 thousandth of an inch)
This is valid for planing oak, when planing fir, I can get sections where I cannot see any light under the straight edge or square. It may be caused by the softer structure of the wood and that it can be pressed a little to close any gaps.
I would like to ask if my results are good enough and I should put up with it or I should improve my sharpening, plane setup or planing technique to get really no light visible under the straight edge across the whole length of the edge or across the whole width of the board. If I check the length of the boards, I can get a tiny hollow in the middle as well, but I know that this is acceptable if it is not too big and it is not a bump.
The gap may cause me the biggest problem when glueing the legs of a table from multiple boards. I need to glue wider boards together face to face. And having a wavy surface on both sides, although miniature, can have a negative compound effect.
Thank you.
Thank you.
