Moving shop,need smaller bench. This is the "beam"; some very 2nd rate sycamore boards planed up and stuck together. Pleased to be able to use them as they were not much use for anything else - knots, wormholes, bark inclusions etc.
Lots of planing fun! Nice camber on a 5 1/2 and a 7 planing across at 45º to flatten it nicely. No flat shavings, what am I doing wrong?
On the light testing theme, see below.
Plane on edge gives a shadow and the light shows up much better. What I do next is to slip a pencil in and mark a line where there is
no light showing, i.e. high points. (Couldn't photo this, not enough hands!) Do this all over the board and you end up with lots of pencil marks. Next step - plane off just the marked areas, and take down the high points. Repeat until flat, testing as you go with winding sticks for twist and squinting down the long edges for straightness
