That Hitachi actually had 16" wheels much like the Makita (had one) and Ryobi versions of the time. Blades were thinner than normal and has Stellite tips. They were meant for job site sawing of softwoods used in Shoji screens and timber buildings. That wood was the best they could get from Western Canada and the US, no knots and perfectly straight grain. The don't work so well on hardwoods.Norm Abram had a small Hitachi resaw he’d use for sawing veneers. It was only the same size as a 12” bandsaw but took a 3” blade.
Hello,Not if you've got a Woodmaster CT, and a saw up to tensioning it!
*other carbide tipped blades are available
Some of John Teneyck's post's (his pics aren't held hostage by Creekers paywall)
https://sawmillcreek.org/showthread.php?299145-Slicing-Veneer-with-the-Amazing-Woodmaster-CT
https://sawmillcreek.org/showthread.php?280590-The-Incredible-Woodmaster-CT
I guess having the right machine for the job, might be seen as OTT?...Hello,
It is funny when people tell you something can't be done, when you've been doing it for years.
I'm not sure if people don't belive what they read or don't read things properly, but when I said earlier that I had cut and lain veneers straight from the saw, and was taught to do so (others clearly were doing the same and passing on the knowledge) I really meant it.
Mike.
How did you do it without the adjustable fence gadget?Hello,
Mike.
Hello,How did you do it without the adjustable fence gadget?
i think you're missing the point, this is my alevel project. And its not as simple as you are making out, theres alot more to consider and do, to make sure you dont waste materials/waste as little as possible.Surely the jig is effectively a micro adjustable fence in itself and you don't need the other fence?
If I had a good enough blade I'd simply cut veneers between fence and blade. I'd set it against gauge marks on the workpiece and not need to set it again until I wanted to change the thickness.
Thank you so much for your help! I will look into different polymers and the anodised aluminium. Thanks for your time. - Elisha.I think it’s a neat idea, for those who didn’t read the first post fully, the jig sits in the mitre slot which she highlights, that keeps it straight and true. She also explains that you slide the jig back out of the way before making a cut, its for set up only, so nothing gets trapped when being cut.
I would make it from plastic with anodised aluminium bits where necessary. Do I think it would sell? Yes. Like every good prototype, you’ve admirable demonstrated its functionality and its utility. In all seriousness consider approaching a company such as Trend to make it with you getting a royalty for everyone they sell.
I think you’re missing the point here Elisha, you’re dismissing the opinions of people who have many years experience of doing this for a living.i think you're missing the point, this is my alevel project. And its not as simple as you are making out, theres alot more to consider and do, to make sure you dont waste materials/waste as little as possible.
I explained in my previous post your jig is perhaps flawed, and even suggested an alternative that might be a better idea.
Oddly enough I was talking to a friend today about her design education. One of her tutors had said that the "product" was not as important as the process.
This is what we see here - a lot of attention to the design process of an otherwise useless product. OK it's a point of view in an educational environment I suppose.
I wonder if Elisha would get higher marks if she not only designed a working product but also showed that it was not in any way an improvement on the usual methods, which she had also researched.
Also it would be a more professional approach - to point out the defects of a clients proposal even if it meant losing the job.
Keep ahead of the game - just say no to useless gadgets!
I’m beginning to think you have shares in this jig.Hello,
For heaven's sake fellas, cut the young woman some slack.
She clearly has to design and make something; she can't get an A level by saying there is no point doing it any differently than the old farts here say they do it.
Has it not occurred to you that your objections are based purely on the supposition that her device won't work. You have not seen or tried the likes before, so you are just guessing. Perhaps you should assume that Elisha has made a rough mock up, that actually is showing some promise to work the way she intends. Enough to build a more refined prototype. If you have no thoughts on any modification or improvement she might incorporate, I'm not sure why you are commenting at all. Telling her that you don't cut veneer as she intends and she is essentially wasting her time is pointless.
Also, have you ever thought that Elisha may not think the jig is a good idea, or may not be a woodworker and never have a use for the device herself? That has nothing to do with her clients desire for it. She just has to design the thing and have it work successfully enough to satisfy the brief set to her. Designers do not have to like the products they design, just do it well and with integrity.
There has been enough evidence given by others here, that cutting veneers that can be laid straight from the bandsaw is achievable. Perhaps the realisation that there are other ways to achieve a result hasn't dawned on some people.
Mike.
She did ask us for a critique.Hello,
I thought it might be a trick brief: design this thing as best you can for a good mark, as she is doing, but get a distinction if you also work out that it's a daft idea to start with!!She clearly has to design and make something; she can't get an A level by saying there is no point doing it any differently than the old farts here say they do it.
Wrong wrong wrong. A "professional' has to act in the clients best interest and say what they think about the job in terms of the clients best interests. More or less what "professional" means..... Designers do not have to like the products they design, just do it well and with integrity.
Good for you Elisha, for standing up and fighting your corner!i think you're missing the point, this is my alevel project. And its not as simple as you are making out, theres alot more to consider and do, to make sure you dont waste materials/waste as little as possible.
hey, thanks for the tip, however its only my A-level so I'm not sure I would take it any further than that.@Elisha Nichols All I can say is make sure no one steals your idea if your intention is to market it.
You've done all the research and design, but have put it all on the internet for anyone to take and make their own.
I speak from experience, as all of my research was plagiarised by a lecturer in conservation at Zagreb university.
