Yes we use the aluminium spike device and it does reduce cooling time and perfect results. We prefer a crispy baked spud so the ultimate solution would be spiked spuds done in an air fryer.
I think there's good and bad double/triple glazing, you pays your money etc. We bought cheap to replace the single pane windows as it was all we could justify at the time.I keep reading how little difference they make, but wonder why if that's the case it's used throughout Northern Countries. According to a long time experienced window fitter I spoke to, the main problem with triple glazing in this country is that the frames produced here aren't deep enough, so the panels made to fit them haven't sufficient gaps.
My mother had a house built 44 years ago - the architect advised her not to have double glazing as it wasn't worth the extra cost for what it saved. I was amazed at the time.
You wouldn't normally fit triple glazing to an existing window - you build (or buy) a frame that suits the triple glazing .... for most uk properties, it's a package deal.According to a long time experienced window fitter I spoke to, the main problem with triple glazing in this country is that the frames produced here aren't deep enough, so the panels made to fit them haven't sufficient gaps.
I didn't mean fitting it to existing frames, the fitter made the point that new frames made in this Country are not designed for the like of 4 - 20 - 4 - 20 - 4 panels - which to be fully efficient they need to be, 20mm being the optimum gap, apparently. The panels are 4 - 9 - 4 - 9 - 4 or thereabouts to fit a standard frame, so little different thermally to a 4 - 20 - 4.You wouldn't normally fit triple glazing to an existing window - you build (or buy) a frame that suits the triple glazing .... for most uk properties, it's a package deal.
I notice quite small newly built properties with windows that to me at least are much smaller than they should be, so I assume they're designed for energy efficiency, but conversely there are "luxury" houses going up everywhere that have huge glass frontages. Odd.
I have used a japanese hand saw for a number of years now and now find it easier to use and keep straight using the back stroke to cutMy needs and finances are about the DeWalt - other brands are available - level. Seriously, I am happy to do my bit. But if you consider the environmental cost in the manufacture of some of these products, where do you draw the line? At my (very low) skill level, I get a better straight line cut with an “ordinary” saw, for which I think I paid about £7 in Screwfix. Plus the exercise keeps me warm, and I didn’t use any electricity.
Claw hammer or pincersNo, you do actually take them out after cooking.![]()
The first step to reduce sound transmission is to draught proof - sound waves pass through any gap.the main benefit of triple glazing is the significant reduction in sound transmission.
4" to 6" spacing ain't at all brilliant for thermal performance though - the internal convection currents see to that.The larger the gap to the double glazed units the more effective the sound reduction is, 4-6" is ideal .
Other colours are available ... grey's quite nice ...warm edge spacer bars between the pains, black in color
As my wife discovered last week when she used my lovely little Nonpareil dovetail saw on a piece of damp 2" x 2" and put a kink in it.I think we have a lot to learn from the Japanese when it comes to woodworking, pulling a saw to cut is really logical as it keeps the blade in tension. Our concept is like pushing string.
The only problem is the glazing in upvc is smaller due to larger frames so costs more to light rooms in the day (side windows on bays im thinking ) I used to build replacement frames in wood to fit double glazing using 50mmx50mm timber upvc is about 75 x60 so 50mm less light all round some side windows end up with less than 225 wide glass showingYou wouldn't normally fit triple glazing to an existing window - you build (or buy) a frame that suits the triple glazing .... for most uk properties, it's a package deal.
Take the workshop key off herAs my wife discovered last week when she used my lovely little Nonpareil dovetail saw on a piece of damp 2" x 2" and put a kink in it.
Material of the devil. This is a woodworking channel!upvc
I used to get calls to my add in the local paper under Joiner "oh hello i would like some upvc windows fitted " sorry im a joiner i work in wood "but its the same thing isnt it "Material of the devil. This is a woodworking channel!
