What burnisher should I get?
tobytools
12 Apr 2013
bournemouth
as the title suggests?
Do I really need one or can I get away with an old file?
What have some of you used and how do you rate them.
Thanks.
TT
Hi Toby
Although I haven't used scrapers much, a burnisher needs to be hard and smooth. I had heard that the curved body of a gouge works well so that is what I have used in the past and it does work well.
An old file ground smooth would be ok but it would take an age to get it smooth enough.
The shank of a solid carbide milling cutter if you have access to a knackered one.
Thanks.
TT
I have the Clifton and I can't imagine there's one better. I have Clifton and 'vintage' Sandvik scrapers too. I found the Lie-Nielsens to be really crappy by comparison. Don't economize (ise) on your scraping kit. They'll get you out of more than just a few jam-a-rooskis.
I have a pax one that I bought from classic hand tools. What can you say about a burnisher? is it hard - yes, does it roll an edge - yes, does it look out of place on the bench - no, is it ridiculously expensive - no, does it smell nice - yes
Matt
Hi
I have a Veritas one, it works for me but as it's the only one I've used I have no means of comparing it's performance.
Regards Mick
Thanks everyone for you advice,
I think I'm going to go for the Clifton or the hock:
Richard T- I'll try out that method you mentioned cheers.
Marcos-I don't even know what one of those is ;)
Carlb40- the LN burnisher looks lovely and cost a pretty bunch. I don't really use scrapers so for now I'll get a mid range one and who knows maby in a year or two I'll up grade, let me know how you get on
Thanks again everyone
TT
I have a Two Cherrys one and its rock hard, and not expensive.
And the two Cherries burnisher that I have is a piece of junk. I went and bought an engine exhaust valve from Ebay for a couple of quid. It's very good as a scraper burnisher, not sure about as an exhaust valve though.
Hi Mignal
I have heard the Two Cherrys can be variable, Valve stems also make good centre punches.
I have a 1/4" solid carbide milling cutter that is going to be a burnisher, but the dam thing keeps going!
+1 for Two Cherries - but as Pete says there does seem to be a bit of variation out there. I'll shortly be moving my Veritas variable burnisher on, I got it in a job lot, and never really found the need for it - Hey ho. It does do a really good job, but then so do I (he said modestly!)
I have a Thomas Flinn one that does the job. Mind you a modern hard screwdriver used to serve before that. Scrapers are only a 0.5% carbon spring steel so not that hard - a bit of hardened silver steel in a handle of your choice ought to be cheap and easy enough to make.
We have sold the Veritas, Pax and Clifton. I used to use a very hard screw driver shaft but it got lost a I never found one hard enough since. My own is a Clifton I am fairly sure it will be the same steel as the Pax but the Clifton's handle is very well finished with a beautifully turned ferrule and a pleasure to use.
Peter
I just ordered the the clifton burnisher as well as a few goodies as I've been of the ebay and Booz ;£
Also just ordered.
3/8 ashley iles DT chisel
Double extra slim taper 15-20 file
Replacement iron for a 112 plane
I also have some new vices and a bench grinder on their way. But don't tell the misses
TT
