Inspector
Nyuck, Nyuck, Nyuck!
Sheffield Tony":v7qrk3ra said:Surely brazing it would lose the temper.
HSS was developed for metal lathes and milling machines because it retained it's edge even when it got red hot. As long as it isn't quenched after heating it will retain it's heat treatment. If quenched it gets microscopic cracks and the edges don't hold up. The same reason you don't dip a HSS tool off the grinder, even if it is blue, to cool it. Opposite of carbon steel which you should not allow to get hot enough to see a colour change. So braze away if you want.
