Flat belt (lineshaft) drive was an option on earlier RB planers.guineafowl21":1f1swiew said:Yes, the machine on the right has a handle sticking up from the fence, and doesn’t appear to have a motor...
guineafowl21":1f1swiew said:...Re knives, what rough dimensions am I looking for? The cutterhead is about 9 1/4” wide. I can measure the pitch of the slots from the adjusters...
Yup, that's exactly what I bought for mine. Same packet (2 per packet - but that advert states price per knife, not per pair) but I paid 29.55 UKP per pair.guineafowl21":1a2fm80v said:Would these do?
The business end of each square head bolt should be pointed - and fits into a countersink in the gimble. Back off the locknut and adjust the bolt so that there is no play (backlash), but not so tight as to prevent the gimble from rotating freely (best done without the handwheel shaft through the gimble). I put a touch of grease into the countersink first - but you may not want to do that in case it attracts too much dust.guineafowl21":24rpnrwo said:The tables are raised and lowered by a handwheel acting on two threaded lugs. Either side of each lug, there are square-headed bolts with locknuts - what are these for? Can they be used to take out backlash, or should I leave them alone?...
guineafowl21":e87zg9k2 said:...One person asked how much it would have cost at the time - any idea?
'Wad', as in they cost a wad of cash. 'Kin', as they are so well built they'll outlast you and get passed on to your kin.guineafowl21":29esoxwf said:...Also, a point raised by a local woodworker:
Should Wadkin rhyme with oddbin, or admin?
If it's on a wooden floor you might feel some vibration, however it doesn't sound right.guineafowl21":1sc4ofhr said:...I can feel some vibration in the floor while it’s running - is this normal, or should I look for where it’s coming from?...
They’re brand new, so I didn’t check the weights. I set them so they both advance a piece of wood 3mm.Trevanion":3bs7xyrc said:Are the knives in true balance and set properly in the cutterblock?
That’s what I thought. I was saying ‘wodkin’, but this chap is saying ‘waddkin’.Vann":3sk6m4zg said:'Wad', as in they cost a wad of cash. 'Kin', as they are so well built they'll outlast you and get passed on to your kin.guineafowl21":3sk6m4zg said:...Also, a point raised by a local woodworker:
Cheers, Vann.
Vann":dlbzm069 said:If it's on a wooden floor you might feel some vibration, however it doesn't sound right.guineafowl21":dlbzm069 said:...I can feel some vibration in the floor while it’s running - is this normal, or should I look for where it’s coming from?...
I'd suggest either bearings are bad or the cutterblock is out of balance.
Regarding the cutterblock, each shell is stamped with a number and must go back on the face of the cutterblock with the same number. They were balanced at the factory (note the drill marks in the flat face of each shell).
The knives must each weigh the same (can't remember the tolerance).
The cutterblock nuts must weigh the same. At least, each opposing pair must be within 0.2 grams of each other - IIRC.
Similarly, the cutterblock studs must weigh the same.
So start by checking the bearings and shells. Then work your way through the knives and nuts. Only tackle the studs if it still vibrates significantly after you've checked the rest.
Cheers, Vann.
Just realised I’m asking a Kiwi how to pronounce vowels...Vann":352uz2k3 said:'Wad', as in they cost a wad of cash. 'Kin', as they are so well built they'll outlast you and get passed on to your kin.guineafowl21":352uz2k3 said:...Also, a point raised by a local woodworker:
Cheers, Vann.
