Wadkin PK riving advice please
markturner
UKW Supporter
11 Mar 2011
London UK
Hi, I have started properly using my Wadkin PK saw which I restored several years ago. Hwever, I notice that the riving knife is not properly aligned with the blade. This is very tricky to adjust, as it simply bolts to a steel bracket. I remember having to get the riving knife made as the saw did not have one.
As it is not aligned co planar to the saw blade, its causing the workpiece to press against the blade when making a cut, burning the wood.
As getting the riving knife properly aligned to the blade is not easy or straighforward, I am considering removing it temporarily while I look into ways to get it fitting correctly.
Are there any particular cuts etc I should avoid if I use it without the knife? Currently I think its causing more potential safety issues than its preventing.
Could you fit a splitter into a diy zero clearance insert plate?
I’m not familiar with that saw, but most Wadkins have a bolt on the side of the spindle housing which you slacken and tap the spindle forward it back to align with the riving knife.
Long rips on thick or twisted timber are the ones where I’ve had the saw cut closeup. If the blade guard is on the riving knife then not having it would be my bigger concern.
