wallace
I thought I'd do a bit pimping out, instead of the normal wood inserts I got some brass flat bar.
To make it fit nice and snug I traced the ends and then glued it onto the brass, then used a disc sander to sand to the line. I had to remove 3/4mm off the thickness.
To do the long edge I had to remove 1.5mm so instead of just sanding I used the router table. and then finished off by sanding.
![](https://proxy.imagearchive.com/728/728746f25d108b21bbe227e260a2c98d.jpg)
![](https://proxy.imagearchive.com/27d/27d4647550309ff3548b445cccc466db.jpg)
![](https://proxy.imagearchive.com/6c4/6c4eb9287dc2e696b3f3d4e07ab7bc2c.jpg)
![](https://proxy.imagearchive.com/3e0/3e0281a895dbe9c0c8d6daae9b534f66.jpg)
