wadkin MJ restoration
Are you going for a full paint job as well? What are your plans for motors? Looks nice and greasy in there!
Hi Andy, yes its getting the full monty. It came with a nice old monster motor but when it fell over it took the brunt of the fall and has a crack in the casing. I haven't investigated it yet.
I degreased and dismantled the gearbox. That must be the most messy job I've done on a machine. My degreaser was pants so I opted for petrol which worked a treat.
There was one set of gears I could not work out how to remove so they got left in.
All clean ready for some paint
Everything on the gearbox is stamped with a 10
There was a small chain which was on a cog at one end and then just riding on a bare shaft at the other, maybe its to move oil around?
Oil would be more normal for a chain drive as lubricant has to penetrate into the rollers etc. Grease would simply get pushed out of the way.
Grease could of been used in ignorance or maybe as a method of managing a leak at some time.
MM
I removed the feed rollers and cleaned
They are quite rusty so are going in the barrel. There is a quite deep scratch on the roller and some pitting, will this affect the performance. I was thinking of giving it a skim.
The roller assembly came up pretty well
This is the piece that was broken I will be welding it soon.
The piece near the cutter head does not seem to be original wadkin
Next I started to remove the head. Its quite a heavy lump.
One bearing looks ok and one side is toast
This is the first time I have opened a wadkin machine and found knackered bearings
Just a wee tip on assessing the rolling element bearings - thoroughly clean the one that appears to be good, and inspect the surfaces of both inner and outer races for any evidence of spalling (tiny bits missing). Do the same with the balls, too (you don't want spalling of the balls). If you find ANY evidence of it, change the bearing - it's in the early stages of failing.
It might be wise to change both bearings anyway, as a matter of course. That cutter block is a big lump, and the better the condition of the bearings, the better the finish you'll get in service.
Thanks for that. If theres any sign of wear I will be replacing. I suspect that they wont be cheap but like you say its not worth the risk with that big lump spinning.
This is one of the pressure rollers after a night in the barrel.
And after a bit elbow grease
Some of the chain guards, pulley wheel and gearbox primed and read for the enamel coats
Got some good news about the bearings, there not as big as I thought so for skf there £54 each or I can go for steel caged for £33
There's nothing on the TV or radio that comes close to matching the excitement of this restoration! More power to your elbow.
This is great to see.
That was clearly made with a huge amount of over engineering to it. Hope you get some good service out of it once fixed up.
Took one of the blocks off and gave it a quick clean to *****. I like to keep all the bolts on a card so that they go back to where they came
I took the other bearing block off and got it ready for some paint. You can see where the remnants of the bearing have got mixed in with the grease on the seal and worn some grooves.
The remnants of the bearing cage have rounded edges
You remember I was banging on about 'spalling' in connection with rolling element bearings a few posts ago - well, the balls on the right hand side of the last picture show classic (and quite advanced) signs of it. Lots of little bits missing from the surface. It wouldn't surprise me at all if the contact paths on the inner and outer races displayed similar symptoms. The little bits of metal that chip out get mixed up with the lubricant in the bearing, and just make things worse.
That's a life-expired bearing, that is!
PS - Good tip about keeping bolts with the holes they came out of - bolts of the same thread and length 'ought' to be interchangable, but on older kit, that's not always the case.
I took the thicknessing table off, a bit rusty but not bad. I did the usual shave then 120 grit at right angle to length then wire wheel followed by scrubber thing.
I then tried to get the main column out of the body.
It was pretty stuck and I did not want to force the gears, So I cleaned it and soaked it in oil and left it for the night
I tried various ways to get it out from rigging the block and tackle up and pulling to levering with a length of wood. In the end I gave it a couple of wacks with a sledge hammer put loads of oil on it and let it be. When I came back to it a couple of days later I put the gear and handle back on and it moved straight away.
I assembled the table, I'm not sure where the rollers should be set. Do they have to be level with either side of the table or proud? Any advice.
The column spent the night in the barrel and cleaned up nicely
There is a little damage
Next I moved onto the gear assembly, this has been taken to bits in the past because it has signs of some dodgy treatment and a bolt had been used as a securing pin.
That is a beautiful piece of machinery emerging from the grime!
Always fascinated by your impressive Wadkin restorations, keep up the fantastic wip.
I had a spray day today.
This was a tight squeeze to get it out
Things got the usual zinc prime and a good few coats of QD enamel, next time I must remember not to spray when its windy I had apples dropping on my head. The good thing about the enamel is you can spray one side and by the time you've done one side the other is ready for another coat.
