Adam W.
A Major Clanger
Superb.
Hi Deema. Yes, I knew about the locating pins thankfully. The tables are off at the moment but due back on later today actually. You’re obviously ‘in the know’ about these machines. Would the two shafts in the gearbox for the Brammer belt & drive-chain pulleys have oil seals? Refilled the box up to shaft level yesterday & getting a slight oil leak. I’ll post some pics later. ThanksNice bag, I think the dominion DAA is an absolutely fantastic PT. The tables are on pins and need lifting vertically off carefully to avoid damaging the cast iron pockets. A number I’ve seen have the pockets damaged due to people not realising. The pins are shown on the photo below
No probs, probably best to create a new thread so that everyone with one can pitch in too
No such thing as a dumb idea the only danger I can think of is that the user may try to fit the wrong fence and crack / chip the table around the pin holes. You can see some chipping around the forward bolt holes where I’m guessing the original fence was attempted to be fitted……iWould making a second fence be a dumb idea? One for each position. Lots more work but then you can make them as close to perfect as you can.
Was the no. 5 "Ebay cracked tub" listed somewhere in the Cambridgeshire fens do you know? I bought mine from a scientologist out there, someone had welded the tub, quite well, and it all works very nicely, Mine is No.8 Stidy ( John Stidworthy) I wonder if they are the same one. Will sort out some photos.Great! Look forward to this Deema. Here's my register of extant BGS10's
Mine, no. 8 on your list, is serial number BGS61232. It has a welded repaired tub, so might have been the saw formally known as no.5 eBay cracked tub. I also have friends in common with sion dovey in pembrokshire, that's another story....Great! Look forward to this Deema. Here's my register of extant BGS10's
A little progress made today before a new addition to the family, my second grand daughter decided to make an entrance to the world. Sideways has bit family stuff for the next week so progress will be slow for a while.
Saw Spindle.
This is probably the trickiest bit to assemble. I’ve certainly got it wrong on more than one occasion. Schematics below show how they go together. The first is an exploded diagram. Item 8 sits inside item 7. It is a locking collar that is pulled against item 7 by a bolt and stops the entire assembly moving inside the casting. You need to move the entire saw spindle in and out of the casting a little bit to align the saw blade with the riving knife. Getting this back together is the tricky bit!
The original bearings which I can only find exact replacements for on the continent at exorbitant prices I replace with SKF or similar 6203 bearings and a couple of shim washers to make up for the protruding inner race. Shim washers are precision shims in the shape of a washer. The only reason for the spacing is to ensure the bearing remains inside the casting when the spindle is moved to its furthest forward position. The original bearings had this ‘packing’ built in. The bearings are identical in specification / performance otherwise.
