jorgoz":10g61pxg said:
The Wadkin manual states 29 amps for 220v 3ph 3hp. The 2.2 kw vfd is rated 10a, the 3 kw 13a and the 4kw 20a.
What is the correlation between what's stated in the manual and for those vfd's ?
Also the manual stated running the motor at low voltage might damage the motor.
Does that not indicate that it is a dual voltage motor???
as I said I'm not very knowledgeable on star motors.
As long as its wired up correctly , I cant see what can go wrong with a motor as long its running at correct speed
as it needs to be running at this speed for cooling itself. a good idea would be to feel the heat with your hand.
A good idea would be to open it up and check for dust anyway
get a marker before you do this and make one continuous line the length of the motor to aid assembly again
it will prob have grime on it so maybe tippex either, you get what i'm saying.
Have you read, or at least glossed over Bob Minchins induction motors pdf?
I run my machines from a 13a plug which is going to an MCB (a regular domestic hager 30a in the house which supplies power to shed)
as long as you dont have a RCD residual current circuit breaker your good to go, as the phantom earth current of the created third phase
prob will interfere with it and set it off.
That diagram looks like Chinglish VFD schematics
Four wires should be coming from the motor, 3 hots and an earth. (a 4 core wire just so ya know)
You have three wires from your household supply live, neutral and earth, this 3 core wire goes into the input of the inverter.
Inputs on some VFD's like the Huanyang are very small, ...( I have pictured these together so you can compare them side by side )
Its a good idea to mount the earths of both the household supply earth, and the motors earth to the VFD's protective cabinet, and have a single earth wire to go into the small earth terminal as trying to get two earth wires into that single terminal could strip the tiny screw threads.
I've posted this all before with piccys and such.
To me, this place insist the same anymore, so I'm not gonna go to significant efforts again as no one gives anymore.
If you feel you are stuck waiting to afford a VFD, or afraid of electricity as of yet, it might be a good idea to go about making VFD enclosures from something you can find.
Good luck
