sploo
Somewhat extinguished member
Either. As far as I can see it should press out from either direction - but it doesn't want to budge. Maybe I'm wrong (all the Wadkin BGY manuals I've found online have no exploded parts diagram)
As far as I can work out, the bearings (dark red stripe pattern) sit against the casting (green).
Having managed to get a better look inside the casting, it actually looks as though the spindle (albeit wider in diameter than the external ends) is not larger than the internal bore of the bearings. I.e. in theory you may be able to push the spindle out without removing either bearing from the casting (I guess it depends on the fit tolerances of the spindle-to-bearing-inner vs the bearing-outer-to-casting).Can you see inside the casting to verify this?
In your photo, the bearing is sunk a little inside the casting. Make washer that spans onto the casting and use the pin nut with your super-spanner to pull the spindle towards the washer.
How is the spindle driven? If there is a disk on one end and a sanding belt on the other, how does the motor transfer its rotation to the spindle?
