Vivarium
Dalboy
18 Sep 2008
Canterbury United Kingdom
Just completed this Vivarium for one of the family they supplied the materials which is melamine covered chipboard. Horrible stuff did not like using it. It measured about 3ft X 2ft X2ft.
I used the bench saw to create the sliding panel frame giving it two slots one for each panel I made the top slots deeper so that the clear panels can be removed
    93.8 KB
Did you seal all the edges? :D
vivariums are 24 hour heated moisture tanks, they'll love untreated chipboard.
There are no cut edges on the inside and there is also a bead of sealer on all of the internal corners. The cut edges that are on the outside will be covered as well but by the new owner
