bugbear
Well, that's not a property of the spiral, that a property of the labels on the spiral.mr grimsdale":1xlbd6f9 said:If the spiral bevel thingy is properly designed - the 'bending point' will be in the same position relative to the length of the tooth for every tooth. So at 4 tpi it will be at n" at 8 tpi it will be n/2" (measured from the tip).bugbear":1xlbd6f9 said:mr grimsdale":1xlbd6f9 said:Yes but the teeth you are adjusting for are longer or shorter so the bend may stay at the same relative position.bugbear":1xlbd6f9 said:....
Surely as you rotate the anvil, the bend point (the spiral arris on the anvil) moves continuously up and down the tooth?
BugBear
"may" appears to be purest optimism! I agree that it's possible you could change the saw-set, and the next tooth just "happen" to match the change you've made, but is seems damnably unlikely.
If that's not what you meant, what did you mean?
BugBear
But the anvil is rounded on mine so there is no single bending point, and in any case the steel is a bit springy so the tooth won't be bent at a neat angle, but the principle will be the same.
You mean the arris rounded? As long as there's still an arris, it has a position (obviously...)
Or to look at it the other way - the further you turn the anvil the higher or lower the (hypothetical) bending point.
Yes, that's what I said. And for any given tooth, there's only one anvil position where that bending point is halfway up a given tooth size. Which is also what I said.
BugBear
