Tart
New member
Afternoon all
I'm a newbie woodworker wanting to make stands for my synthesisers and maybe a cajon or two if i can. I enjoy working with my hands so i decided to delve into some big-boy/girl Lego.
I recently bought a pair of Swanson speed squares and performed the lined paper test to test their squareness, after hearing how un-square a lot of tools can be. I also purchased a Faithfull FAIES6 Engineers Steel Try Square 150 mm (6 Inch) to verify it's squareness.
The lines that i drew using the speed squares were dead on so i was happy with that. However, when i used the engineering square, on the side of the speed square that i drew the lines with, i can see little bits of light peaking through when holding it up to a light. No big gaps, very slight.
Can anyone explain the logic of this and if it even matters?
(note that i also did line test with the engineers try square and that was also spot on).
