tisdai
Thanks for the info Bob, great of you to post it here for everyone
Dave
Dave
9fingers":3tax8az7 said:The prices look a lot closer than 3 :1 but anyway
Sounds like you have been looking at inverters from Drives Direct. Provided the modified inverter is rated around twice the output that you need, the modified inverters should work OK. I've modified a few recently myself and they seem to work oK but I've yet to give them a thorough testing.
If you want to go down the converter route, then adding a motor to make a rotary converter should enable it to run either of your machines.
Bob
drmartin1981":xycignwn said:Hi Bob,
I'm currently using a JET band saw with an induction motor on it, Im a novice with reguards to motors so found your write up very informative and helpful in understanding exactly what I'm using.
Im happy with the performance of the induction motor!
'Tis the best info you'll find, and freely available to download, not here though, but another forum,Is this pdf still available somewhere?
