ByronBlack
Ian,
I think you may be over-complicating things a little. I've made a fair bit of furniture and guitars (which usually need very low MC) and have never worried about the moisture content too much - I always acclimatise the wood to its final destination for a few weeks (after dimension the wood close to its final size), and then bring it into the workshop to work on - if its a long project (in time) i'll bring the wood back into the house or wherever its going to go between session. So far I have had zero issues.
If you plan your projects to accommodate wood movement, then most of your problems are catered for.
As for your beech, I would have started making the base as soon as it was within a few percent of your shops natural MC, and while building the base, let the pieces for the top continue to dry, when you glue them up in a lamination, they really won't move too much once you have flattened them.
You really don't want to leave wide boards drying if at all possible as the likely hood of cupping is much greater, instead you want to rip them down to 1/2" or so of your final dimension, this means they dry quicker, and gets any movement out of the way ready for final dimensioning.
