I'm not really going to argue this one too much, but....... The standard approach taught in colleges since the 1960s is to use one or two push sticks and keep your hands some 350 to 400mm away from the blade at all times if possible. In reality I tend to man-handle materials right up until the last foot or so then just pick-up a push stick and push through. .
If you use an "overhand" pusher such as yours that will lead to your hand at the end of the rip being beside the saw blade between the fence and the blade and will put you in a position of potentially having an arm over the top of the crown guard or moving across the front of the blade. If you were to execute that manouvre on a saw with an overhead crown guard such as a my panel saw or Seaco's overhead crown guard you'd risk getting entangled in the guard support. Try it on a larger diameter saw, such as this Wadkin BSW rip saw:
and even with the nosing guard pulled down you'll be running the risk of injury. Same goes for the bandsaw. The forward position pusher such as yours
might at a tight pinch be regarded as all right on a 10in saw with a crown guard mounted atop the riving knife, but with a suspended SUVA-type guard the guard suspension mechanism gets in the way and on bigger circular saws or band saws the blade itself becomes an very dangerous obstacle. The rule is simple - don't bend body over a blade. Even on a 12in saw you could have as much as 4in (vertical) of blade exposed at the end of cut, after the material has gone through - more than enough to get a skin/blade contact. the bigger the machine, the greater the danger. But I'd also suggest that you don't want your hand alongside the blade just in case that cracked bit at the end of the piece breaks off, richochets off the crown guard and raps you smartly over the knuckles. But then I'm a natural coward.
And who's to say what an amateur woodworker may have in their workshop? Before anyone says it I have known self-builders with 16in Dominion Elliott combination saws and even one brave soul with a 24in Wilson rip saw on a single phase motor. So that makes me a traditionalist and naysayer, I'm afraid, on the subject of American push-stick design :roll:
Scrit
