Hi
When you look at the Triton website they state " Removable plunge spring for easy bit adjustment when table mounted " and it is only retained by a single screw so designed to be easily removed. It is a great router for the money and the only plunge router that can be height adjusted from above the table.
Now if you already own one then the Jessem lift plate will provide not only a very smooth and precise lift mechanism but repeatability which is what I currently have issues with and precise incremental change. Here I think the Triton has another bonus, in a standard Kreg plate when fully raised for a bit change it stands 12mm above the plate so you should not require an extension when fitting to the Jessem lift plate where you lose 15mm if you can accept losing about 3mm of max lift(Theoretical). To do this you would remove the locking mechanism and fit a type 8 muscle chuck if you have the later machine with external chuck mounting threads.
Now if you don't have an existing router setup and are looking into possibily getting one then initially you will think £764 for the AUK machine in a Jessem
JessEm Mast-R-Lift II with remote switch and variable speed seems expensive, I did but the Jessem prestige is £335, a Triton Tra001 is £220 and the muscle chuck another £70 giving a total of £625, only £139 difference in the two setups!
