After a lot of faffing around with Uploadit (still can't upload pic's) I've decided to use Photobucket, so I'm re-posting the last lot of pic's.
First I had to take the rough off some cherry in preparation for the drawers, originall I thought of only having the one drawer, but then decided on two becasue I thought it would look better .
[/img]
I'm resawing the wood to 1/2" so when final prep is made it will be 3/8" which I think is a good thickness for the drawer sides and back.
This shows the drawers stock resawn.
Next job is to size the back, sides and front of the drawers to the carcas, luckily enough they are as near as damit the same size, I always worry that I've got my measurements slightly out here, but not this time.
I've decided to join the drawers together using dovetails and these are going to be handcut, I do have the Leigh Jig that I could use , but there is something about cutting them yourself.
The technique I'm using is from Rob Cosman, first is to mark them off, notice that I've assembled all the tools that will be required for the job.
This tail board is showing the pins on the first joint.
Both pin boards are now rough cut.
Now all thtas required is the rough taking out from between the pins with a nice sharp chisel, for this I'm using Blue Spruce DT chisels.
Now all thats left is to do the tails, this I will do later today.
